Karaburan
Project Karaburan | |
Monitoring water quality | |
Status | Initializing |
Contact | bertrik |
Last Update | 2024-04-29 |
Topics:
- air quality sensors
- ammonia
- NOx
- water chemical analysis
- nitrates
- ammonia
- dissolved oxygen
- sulfide/sulfate
- phosphates?
- salinity (chlorides?)
- water physical analysis
- temperature
- depth?
- boat control
- trajectory -> steering
- camera control
- post-processing
- data presentation
- video/photo stitching
- time lapse view
- map view of properties
- data presentation
- use cases
- minimum viable prototype
- materials
- boat selection
Air quality sensors
Nitrogen compounds in air
- NOx: 27.3 ug/m3
- NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
Drinking water upper limit: 4 NTU (European turbidity standard for drinking water) Ambient water: 10-150 NTU. The US state of Washington use a "background" value of 50 NTU as reference. (see https://en.wikipedia.org/wiki/Turbidity#Standards_and_test_methods )
So the Aliexpress sensor is mostly suited for very dirty water.
Boat control
- 2.4 GHz working frequency
- 500m range
Interesting links:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
- slootview, inspect water sides over time
