HAB Tracker Station
Project HAB Tracker Station
Contact User:Costyn_van_Dongen, Maxell, Bertrik_Sikken
Last Update 2013-02-11
Project page for the high altitude balloon tracking/listening station we are setting up in the space.
Overview
Done
  • rtl_tcp on RasPi over the network --> works! (1024000 samples/second seems to go fine when both are on a wired connection)
  • VNC performance with gqrx and dl-fldigi --> usable with JPEG compression and 8 bits of color (why not SPICE? http://www.spice-space.org/)
Todo
  • Piece of pipe with a inside diameter of 29mm
  • Setting up a virtual machine with gqrx and dl-fldigi.
    • If we are going to use SPICE we could setup a whole new machine. Or at least some sort of Fedora desktop virtual machine.
Shit just got real
<foobar> Maxell: had xander gevraagd over die plaatsing van een antenne, is geen probleem, mits netjes aangelegd/afgewerkt
<foobar> je kan eventueel bij de zonne-collector naar binnen, daar is al een kabelgoot o.i.d.
<foobar> komt uit in de wc's boven, kan dan door naar de meterkast, en vanaf daar zijn al ducts naar beneden/kelder
OMG! HUGE SUCCESS!
The old geyser's ventilation pipe is still penetrating the roof. Cat5e UTP and 230v at your fingertips. It looks like we don't need to put our setup on the roof anymore, just the antenna! The enclosure we are going to use doesn't need to battle mother nature anymore, easy replacement if something breaks, etc, etc.
Grounding
<costyn> so guys, how do you ground your antenna's? what the consensus on lightning arrestors?
<fsphil> there's so little lightning here I don't bother
<costyn> hmm
<costyn> we're going to place an antenna on the roof of our hackerspace, but it's not our building and we'll have to convince the owners that it's safe
<SpeedEvil> you need to ground to a separate rod, with a straight cable to it
<SpeedEvil> thick insulated cable
<costyn> define thick?
<gonzo_> you are only going to be able to disipate static with earthing. very little you can do against a direct strike
<gonzo_> most lightening arrestors are really just spark gap's, that allow some high voltage coming down the centre of the coax, to jump to the outer.
<gonzo_> your typical short colinear is possibly going to be DC short between the centre and braid anyway. (You can test with a DVM)
<gonzo_> long colinears are not much of an advantage for HAB use, so I assume it will be a short one. So will not extend much above the existing roof profile? So will not be any greater risk of lightening than anything else
<costyn> gonzo_: it'll be a short one yea, Diamond X-50 likely
<costyn> gonzo_: and it'll raise some above the roof line, but it's not a high building (2 stories) and there's higher buildings and trees around
<gonzo_> not siure of your mounting options, but if mounted to existing metalwork up there, like handrains etc, it will be earthed to the building anyway (or at least the owners metalwork)
<costyn> it's basically a flat roof with some outlets for hvac
<costyn> so no existing metal work. we're thinking of using/making a stand with metal weighted down with tiles
<gonzo_> then an extra ground wire would prob be worth adding. If the building or roof is metal, then that could be an option to earth to, or as SpeedEvil said, an earthing rod
<costyn> ok. thanks for the advice. will see what we can do. not even sure if we're going to get permission to route the coax on the outside of the building, so we'll see
Pics
