GorbaDisplay
Project GorbaDisplay
Public transport LED display
Status Initializing
Contact bertrik, User:Eloy
Last Update 2023-08-08
This project is about reverse engineering a former public transport LED display. It consists of Z panels of each X * 16 LEDs. Each panel has 16 amber LEDs vertically.
The plan is to make the display fully addressable as a bitmap display over a network connection, preferably with individually controllable brightness per pixel.
TODO:
  • more reverse engineering by tracing out the connector to the individual lines of the integrated circuits -> mostly done now
  • is there a separate power supply line to the board? if so, can we power our new microcontroller from the 14-pin connector? -> NO appears to be only 2.2V!
  • measure clock frequencies (column clock, line update frequency) of original controller board
  • write software to control this thing, e.g. for ESP8266
  • investigate https://github.com/qisun1/ESP8266_LED_64x16_Matrix , seems to be a similar display
14-pin header + chips
  • a control board, with logic to receive (for example) text messages over a serial connection and convert them to a bitmap display on the display board
  • a display board, with logic to light up each LED, consisting of 4 panels of 16x16 LEDs each
Each panel appears to work almost independently: it has its own power supply circuit, receiving input through a 14-pin connector and forwarding data to the next panel using another 14-pin connector. Each panel receives 24V and contains an LM2678 chip, also known as the Texas instruments "simple switcher", to drop the voltage down to approximately 2.2V.
Each display panel contains the following integrated cicruits:
  • 74HC541, an octal buffer/line driver, buffers most of the signals coming in from the 14-pin connector to the rest of the electronics on the panel
  • 74HC238, a 3-to-8 line decoder/demultiplexer, probably selects which row is currently being lit up
  • group of 4x IRF7425, power MOSFET, probably for driving a 1-out-of-4 row of LEDs
  • a whole bunch of TPIC6C596, 8-bit shift register, probably drives the columns inside one row of LEDs
Each LED has a 10 ohm resistor in series. LEDs are amber/orange.
Theory of operation
This is probably a row-multiplexed display.
Each 32x16 panel contains 512 LEDs and 16x8-bit shift registers. Multiplexing is therefore probably 1-in-4.
A panel can light up four rows at a time. By quickly lighting up each row in succession, the illusion to a human observer is that all LEDs are controlled simultaneously.
row demultiplexer
The demultiplexer is capable of handling 3 bits, enough for 8 rows.
column registers
Each panel contains 32x16 pixels. It has a shift register consisting of 16 TPIC6C596 circuits organised in 4 rows of each 32 pixels. The shift registers of one panel are wired up in series. At the end of the shift register chain of each panel, there is another 596 chip, the output feeds into the data pin of the output 14-pin connector.
Possibly one out of four rows can be lit at a time this way.
14-pin connector
Connections
Pin Id Remark
1 GND Ground
2 GND Ground
3 ROW_SEL0 74HCT541:A3-Y3 -> 74HCT238:A0
4 ROW_SEL1 74HCT541:A2-Y2 -> 74HCT238:A1
5 ROW_SEL2 74HCT541:A1-Y1 -> 74HCT238:A2
6 ? 74HCT541:A0-Y0 -> ?
7 ?
8 ?
9 COL_DATA 596:SER_IN
10 COL_ENABLE 74HCT541:A4-Y4 -> 596:G
11 COL_CLOCK 74HCT541:A5-Y5 -> 596:SRCK
12 COL_LATCH 75HCT541:A6-Y6 -> 596:RCK
13 VCC Power, about 2.2V
14 VCC Power
There are possibly pins for:
  • row select, bit 0
  • row select, bit 1
  • row select, bit 2
  • row select, bit 3
  • row-enable
  • shift register data
  • shift-register clear
  • shift-register data
  • analog LDR value
  • remote control input
  • power pin
  • ground pin
Repository: https://github.com/bertrik/GorbaDisplay
