PowerLight
Project PowerLight
Show energy mix of dutch power generation as a pie chart on a LED ring
Last Update 2022-10-01
The concept
Draw the current dutch electrical power generation-mix as pie chart on a LED ring light, with colors representing fractions of a specific power generation source.
For example:
  • yellow: solar
  • blue: wind
  • red: fossil
  • green: nuclear
  • grey: other/waste
Power generation data
ENTSO-E data
  • B01 (biomass): always 0, not useful
  • B02: not available
  • B03: not available
  • B04 (fossil hard coal): useful
  • B05 (fossil gas): useful
  • B06: not available
  • B07: not available
  • B08: not available
  • B09 (geothermal): not available
  • B10 (hydro): not available
  • B11 (hydro): always 0
  • B12 (hydro): not available
  • B13 (marine): not available
  • B14 (nuclear): useful
  • B15 (other renewable): not available
  • B16 (solar): hugely underreported, *not* useful
  • B17 (waste): useful
  • B18 (wind offshore): useful
  • B19 (wind onshore): useful
  • B20 (other): useful
  • B16 (solar)
A model for the energy generation mix of the Netherlands
For me, the most insightful information came from this article by Bert Hubert: https://berthub.eu/articles/posts/dutch-electrical-power-figures-2/
Main points relevant for me:
  • the solar part reported to entso-e is way too small
  • on-shore wind data is unreliable, but off-shore wind data is probably OK
  • no useful biomass data is reported to entso-e
Note also in https://energy-charts.info/charts/energy_pie/chart.htm?l=en&c=NL how the solar part is tiny
There is a model that estimates the solar fraction, also at a regional level and at fine time resolution, at https://api.netanders.io/ I However use of this model requires a paid subscription, so I won't use that.
In my application, energy generation fractions are calculated as follows:
  • solar = B16 (from the forecast document A69), since reported solar generation is known to be incomplete
  • wind = B18 (offshore, from generation document A75) + B19 (onshore, from forecast document A69)
  • fossil = B04 (gas) + B05 (coal)
  • nuclear = B14
  • waste = B17
  • other = B20
Data schedule
Parts:
  • The backend part that collects the power generation data, written in Java, running on a VPS
  • The light part that visualizes the power generation as fractions on a LED ring, running on an Arduino
Backend
Runs as a REST-like resource at:
(1-minute rate limit)
Returns a JSON-structure like:
  "time": 1657057500,
  "total": 9122,
  "mix": [
    { "id": "solar", "power": 0, "color": "#FFFF00"},
    { "id": "wind", "power": 4, "color": "#0000FF"},
    { "id": "fossil", "power": 86, "color": "#FF0000"},
    { "id": "nuclear", "power": 5, "color": "#FF00FF"},
    { "id": "other", "power": 4, "color": "#444444"},
    { "id": "waste", "power": 1, "color": "#444444"}
  • time is a unix time stamp in seconds, representing the end of the 15-minute period that the power figures refer to
  • total is the total most recent electrical power (megawatt), suitable for display (on a numeric display inside the ring for example)
  • mix is an array of power sources, each with:
    • a short unique id
    • most recent known power (megawatt)
    • hex color, for display on the led ring
Display
Powerlight
Shows the dutch energy generation mix by source. Source code: https://github.com/bertrik/PowerLight
ElectricityPrice
T-Display
SHA-badge
Micropython:
  • ++ possibly quick development, script can be shared with other people
  • ++ has working libs for fetching HTTP, decoding JSON, controlling the display
  • -- script needs frequent garbage collection to avoid crashing?
  • -- unclear how to get a python script on this thing
  • -- sha badge firmware bootloops, currently unusable to me
Arduino:
  • ++ I know this environment, don't have to debug existing bootlooping firmware, no compiler setup required
  • ++ Already have HTTP and JSON working on Arduino
  • ++ Code starts immediately, no user interaction required
  • -- not sure if there is a usable epaper driver
