PowerLight
Project PowerLight
Show energy mix of dutch power generation as a pie chart on a LED ring
Last Update 2022-08-18
The concept
Draw the current dutch electrical power generation-mix as pie chart on a LED ring light, with colors representing fractions of a specific power generation source.
For example:
  • yellow: solar
  • blue: wind
  • red: fossil
  • green: nuclear
  • grey: other/waste
Power generation data
Power generation categories
The backend uses the following categories
ENTSO-E numbers the production types from B01 to B20 ("PsrType"), how these are filled for the netherlands:
  • B01 (biomass): always 0, not useful
  • B02: not available
  • B03: not available
  • B04 (fossil hard coal): useful
  • B05 (fossil gas): useful
  • B06: not available
  • B07: not available
  • B08: not available
  • B09 (geothermal): not available
  • B10 (hydro): not available
  • B11 (hydro): always 0
  • B12 (hydro): not available
  • B13 (marine): not available
  • B14 (nuclear): useful
  • B15 (other renewable): not available
  • B16 (solar): hugely underreported, *not* useful
  • B17 (waste): useful
  • B18 (wind offshore): useful
  • B19 (wind onshore): useful
  • B20 (other): useful
The solar power problem
In particular the solar power fraction is incomplete, but also the biomass figures are missing. See:
There is a model that estimates the solar fraction, also at a regional level, at https://api.netanders.io/, however use of this model requires a paid subscription.
What I'm currently doing for the solar fraction, is to use the ENTSO-E forecast instead of the actual solar numbers reported to them, see yesterday's wind/solar forecast. Perhaps this can also be done for the wind fraction.
Data schedule
Parts:
  • The backend part that collects the power generation data, written in Java, running on a VPS
  • The light part that visualizes the power generation as fractions on a LED ring, running on an Arduino
Backend
Runs as a REST-like resource at:
(1-minute rate limit)
Returns a JSON-structure like:
  "time": 1657057500,
  "total": 9122,
  "mix": [
    { "id": "solar", "power": 0, "color": "#FFFF00"},
    { "id": "wind", "power": 4, "color": "#0000FF"},
    { "id": "fossil", "power": 86, "color": "#FF0000"},
    { "id": "nuclear", "power": 5, "color": "#FF00FF"},
    { "id": "other", "power": 4, "color": "#444444"},
    { "id": "waste", "power": 1, "color": "#444444"}
  • time is a unix time stamp in seconds, representing the end of the 15-minute period that the power figures refer to
  • total is the total most recent electrical power (megawatt), suitable for display (on a numeric display inside the ring for example)
  • energymix is an array of power sources, each with:
    • a short unique id
    • most recent known power (megawatt)
    • hex color, for display on the led ring
Energy generation sources are calculated from sources as follows, mostly from document A75:
  • solar = B16 (from the forecast document A69)
  • wind = B18 + B19
  • fossil = B04 + B05
  • nuclear = B14
  • waste = B17
  • other = B20
Display
Powerlight
Shows the dutch energy generation mix by source. Source code: https://github.com/bertrik/PowerLight
ElectricityPrice
T-Display
SHA-badge
The SHA2017 badge has an ESP32 capable of performing the HTTP request, processing the JSON and displaying the result on its display. It has a 296x128 pixel epaper panel.
Micropython:
  • ++ possibly quick development, script can be shared with other people
  • ++ has working libs for fetching HTTP, decoding JSON, controlling the display
  • -- script needs frequent garbage collection to avoid crashing?
  • -- unclear how to get a python script on this thing
  • -- sha badge firmware bootloops, currently unusable to me
Arduino:
  • ++ I know this environment, don't have to debug existing bootlooping firmware, no compiler setup required
  • ++ Already have HTTP and JSON working on Arduino
  • ++ Code starts immediately, no user interaction required
  • -- not sure if there is a usable epaper driver
