PowerLight
Project PowerLight
Show energy mix of dutch power generation as a pie chart on a LED ring
Last Update 2022-07-05
The concept
Draw the current power generation-mix as a kind of pie chart on a LED ring light, with colors representing a fraction of a specific power generation source.
For example:
  • blue: wind power
  • yellow: solar power see below
  • green: power from biomass see below
  • purple: power from nuclear
  • red: fossil
  • grey: other
Power generation data
This is a bit of a problem. There is no open data available with reasonably complete power generation fractions!
The solar power problem
In particular the solar power fraction is incomplete, but also the biomass figures are missing. See:
There is a model to estimate this fraction at https://api.netanders.io/, however you cannot use this API without a key (and you can't just get a key).
Parts:
  • backend part that collects the power generation data
  • light part that visualizes the power generation as fractions on a LED ring
Backend
To be implemented, this will probably run on my web page stofradar.nl. Some REST-like resource like http://stofradar.nl:9001/power/latest
Returns a JSON-structure like:
  "time": 1656490664,
  "total": 1600,
  "energymix": [
    { "id": "solar", "percent": 40, "color": "#FFFF00"},
    { "id": "wind", "percent": 25, "color": "#0000FF"},
    { "id": "fossil", "percent": 25, "color": "#FF0000"},
    { "id": "biomass", "percent": 5, "color": "#00FF00"},
    { "id": "nuclear", "percent": 5, "color": "#FF00FF"}
  • time is a unix time stamp in seconds, representing the end of the period that the power figures refer to
  • total is the total current electrical power usage, suitable for display (inside the ring for example), unit yet to be determined
  • energymix is an array of percentages along with their colors, to be displayed clockwise on the led ring, mandatory fields
    • percent
    • color
Light
Source code: https://github.com/bertrik/PowerLight
