PowerLight
Project PowerLight
Show energy mix of dutch power generation as a pie chart on a LED ring
Last Update 2022-07-05
The concept
Draw the current power generation-mix as a kind of pie chart on a LED ring light, with colors representing a fraction of a specific power generation source.
For example:
  • blue: wind power
  • yellow: solar power see below
  • green: power from biomass see below
  • purple: power from nuclear
  • red: fossil
  • grey: other
Power generation data
This is a bit of a problem. There is no open data available with reasonably complete power generation fractions!
The solar power problem
In particular the solar power fraction is incomplete, see also:
There is a model to estimate this fraction at https://api.netanders.io/, however you cannot use this API without a key (and you can't just get a key).
Parts:
  • backend part that collects the power generation data
  • light part that visualizes the power generation as fractions on a LED ring
Backend
To be implemented, this will probably run on my web page stofradar.nl. Some REST-like resource like http://stofradar.nl:9001/power/latest
Returns a JSON-structure like:
  "time": 1656490664,
  "total": 1600,
  "energymix": [
    { "id": "solar", "percent": 40, "color": "#FFFF00"},
    { "id": "wind", "percent": 25, "color": "#0000FF"},
    { "id": "fossil", "percent": 25, "color": "#FF0000"},
    { "id": "biomass", "percent": 5, "color": "#00FF00"},
    { "id": "nuclear", "percent": 5, "color": "#FF00FF"}
  • time is a unix time stamp in seconds, representing the end of the period that the power figures refer to
  • total is the total current electrical power usage, suitable for display (inside the ring for example), unit yet to be determined
  • energymix is an array of percentages along with their colors, to be displayed clockwise on the led ring, mandatory fields
    • percent
    • color
Light
Source code: https://github.com/bertrik/PowerLight
