Lange lichtkrant
Project Lange Lichtkrant
Status Initializing
Contact Sebastius, Maxell
Last Update 2022-05-07
Sebastius vond zomaar ergens een hele lange ledbanner. 7 meter lang, 1 regel hoog. Deze is inmiddels (op 29 november 2016) aangeschaft voor 150 euro. Helaas was de behuizing uit één stuk en kon deze niet mee. We hebben de diffusers, ledboards, controller, voedingen en bekabeling.
What
It's a long LED banner, 7 pixels high, very long.
Parts:
20x Ledboard (ca 34,5cm lang per stuk), 5 karakters per bordje
 1x Controllerboard
 2x 5v 20A voeding
 2x Kabelboom 5v
 1x Ethernet - Serial brug (Lantronix UDS1100)
 1x Serial kabel
 4x CDRom met software (Twee CD's hebben de installer van het lichtkrant-programeertooltje (MLN v2.20), verder een Cd met driver en CD met quick guide van de UDS1100 (met papieren boekje!)).
 1x Handleiding
Where
Momenteel is dit project opgeruimd, ingepakt in een SAMLA in de lounge. De diffusers liggen in de lounge achter de bank.
Reverse engineering
lichtkrant PCB
Each panel is 30 pixels wide, 7 pixels high.
Parts:
  • 2x74HC245 (U1/U2): 8-bit bus transceiver with 3-state output
  • 5x74HC595 (U3 and U4/U5/U6/U7): 8-bit serial shift register
  • 1x74HC164 (U8): 8-bit serial-in, parallel-out shift register
  • 2xSTA402A: quad PNP darlington
Power is supplied separately from the 12-pin connector, left of the twin darlingon chips.
Connector (top right):
  • 1: GND
  • 2: pin U2.B0
  • 3: pin U2.B5
  • 4: jumper between U2 and U3
  • 5: ?
  • 6: pin U2.B2
  • 7: pin U2.B3
  • 8: pin U1.OE
  • 9: pin U2.B4
  • 10: GND
  • 11: ?
  • 12: ?
The STA402A transistor base inputs are fed through the set of 7 resistors just left of U3 (595), very likely the row inputs.
The panel has three identical connectors of 12 pins each (they are not electrically identical).
Theory of operation
Possibly the column data is contained in the top chain of 4x74HC595 on top of the board. There are 30 resistors there also, exactly the number of rows.
Actuation of a row is probably done by the drivers inside the twin STA402A. The 595 probably acts as the row selection registers, the twin 245's acting as buffer and twin STA402A's as driver.
It is not completely clear what the 1x74HC164 does.
Foto's
Donaties
Er is meer gedoneerd dan verbruikt. De resterende 50 euro wordt gebruikt om materialen ter montage aan te schaffen.
Naam/Nick Bedrag Betaald?
Juerd 25 Ja, Gebunqerd.
flok420 5 Ja, revbank
Peetz0r 25 Ja, revbank
Sebastius 40 -
Jelle 10 Ja, revbank
Maxell 20 Ja, contant aan Sebastius
Crashjuh 10 Ja, revbank
CFW 10 Ja, via RevBank aan Sebastius
HansG 10 Ja, contant aan Sebastius
Smeding 10 Ja, revbank
merethan 25 Ja, revbank
Luteijn 10 Ja, contant aan Sebastius
