Pasjesprinter
Revision as of 12:40, 8 April 2022 by Bas (talk | contribs) (Specs)
Project Pasjesprinter
Een printer, maar dan voor pasjes
Contact sebastius
Last Update 2022-04-08
Handleiding
File:Evolis Pebble 3 Printer User Manual.pdf
Aansluiten
  • 24V DC adapter, center positive, 24V 3A.
  • USB B en Centronics als mogelijkheden. Gebruik USB ;)
Drivers
Evolis website, Pebble 4 drivers werken goed.
Specs
  • Print speed 150 cards/hour in full color (YMCKO), Up to 1000 cards/hour in monochrome1
  • Resolution 300 dpi (11,8 dots/mm)
  • Card types: PVC, Composite PVC, PET, ABS and special varnished plastic cards
  • Card format: ISO CR-80 - ISO 7810 (53,98 mm x 85,60 mm - 3.375" x 2.125")
  • Card thickness: From 0,25 mm (10 mil) to 1 mm (40 mil)
  • Card feeder capacity: 300 cards (0,25 mm- 10 mil) - 100 cards (0,76 mm - 30 mil)
  • Card output hopper capacity: 150 cards (0,25 mm - 10 mil) - 50 cards (0,76 mm - 30 mil)
  • Printer size: Height: 192 mm (7.55"), Length: 396 mm (15.59"), Width: 235 mm (9.25") - Printer weight: 5,9 Kg (13 lbs)
  • Environmental: Min / max operating temperature: 15° / 30° C (59° / 86° F) - Humidity: 20% to 65% non-condensing - Min / max storage temperature: -5° / +70° C (23° / 158° F) - Storage humidity: 20% to 70% non-condensing
Accessoires
Monochrome ribbons
  • P/N: R2011 Black ribbon 1000 cards/roll
  • P/N: R2012 Blue ribbon 1000 cards/roll
  • P/N: R2013 Red ribbon 1000 cards/roll
  • P/N: R2014 Green ribbon 1000 cards/roll
  • P/N: R2015 White ribbon 1000 cards/roll
  • P/N: R2016 Gold ribbon 1000 cards/roll
  • P/N: R2017 Silver ribbon 1000 cards/roll
  • P/N: R2018 Scratch off ribbon 1000 cards/roll
  • P/N: R2019 BlackWAX Black ribbon 1000 cards/roll
Multi-Panels Ribbons
  • P/N: R3011 5 Panel Color Ribbon - YMCKO (Yellow, Magenta, Cyan, Black TT and Varnish) 200 cards/ribbon
  • P/N: R3012 2 Panel Monochrome Ribbon - KO (Black TT and Varnish) 500 cards/roll
  • P/N: R3013 Half-Panel Color Ribbon - YMCKO (Yellow, Magenta, Cyan, Black TT and Varnish) 400 cards/roll
Hologram ribbon
  • P/N: R4001 Optoseal® Hologram Ribbon 350 cards/ribbon
Cleaning accessories
  • P/N: A5011 UltraClean Cleaning Kit (for complete cleaning of the printer)5 pre-saturated cleaning cards, 5 swabs, 1 box of 40 pre-saturated wipes
  • P/N: A5002 PrinterClean Cleaning kit (for cleaning of the transport rollers)50 pre-saturated cleaning cards
  • P/N: A5003 HeadClean Cleaning kit (for cleaning the print head)25 swabs
  • P/N: A5004 DustClean Cleaning kit (for maintaining the cleaning roller)1 box of 40 pre-saturated wipes
