LoRa-E5-mini
Project LoRa E5
Arduino on the LoRa-E5 module
Last Update 2021-10-09
The plan
  • replace the original "AT" firmware with Arduino based firmware
  • use the BasicMac library for LoRaWAN
  • use platformio as the build system
  • create some basic examples for use as a LoRaWAN node on TheThingsNetwork
The hardware is the LoRa-E5 module from seeed studio, contains the STM32WLE5JC:
https://github.com/bertrik/lora-e5
There appears to be support for various kinds of WL55 boards: https://github.com/stm32duino/Arduino_Core_STM32/blob/main/boards.txt
Support for this board in this archive: https://github.com/dolfandringa/Arduino_Core_STM32/blob/master/variants/STM32WLxx/WL54JCI_WL55JCI_WLE4J(8-B-C)I_WLE5J(8-B-C)I/boards_entry.txt#L62  ???
Development environment
Load the .ino file. Compile with ctrl-R.
Programming over SWD
Connect an ST-LINKv2 as follows:
  • SWDIO to PA13
  • SWCLK to PA14
  • GND to GND
Hold BOOT, then press RST and execute:
 openocd -s /usr/share/openocd/scripts -f interface/stlink.cfg -f target/stm32wlx.cfg
Result:
Open On-Chip Debugger 0.11.0
Licensed under GNU GPL v2
For bug reports, read
	http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 500 kHz
Info : STLINK V2J17S4 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.258730
Info : stm32wlx.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : starting gdb server for stm32wlx.cpu on 3333
Info : Listening on port 3333 for gdb connections
Or program over serial?
Getting it to work
Got a flashing LED sketch to work:
  • install Arduino IDE
  • install the STM32 support
  • choose the right board
  • upgrade the firmware of my stlink2 (tool from ST)
  • run the cubestm environment to use the stlink2 to disable the firmware protection
  • flash a simple blinky sketch to the board
Serial port does not work yet, it is connected to PB6/PB7. I need to configure an alternative setting for the pins, don't know exactly how to do that on Arduino.
Node configuration in TheThingsNetwork
