VirtualTour2
Revision as of 15:52, 2 December 2012 by FooBar (talk | contribs)
Virtual Tour of the Revelation Space hackerspace at De Verlichting.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150224.jpg
This is the exit to the Spoorlaan, when coming from the Westvlietweg. You can see the train-bridge and the A12 motorway is behind it.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150257.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_150313.jpg
Standing on the intersection, head into the Spoorlaan, which (for cars) is a dead-end road.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150324.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_150527.jpg
Go down the street for about 400 meters... until you get to the 'Verlichting' complex.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150544.jpg
Building 'A'
http://revspace.org/Rev2Tour/resized/IMG_20121202_150600.jpg
Building 'B'
http://revspace.org/Rev2Tour/resized/IMG_20121202_150646.jpg
Building 'C'
http://revspace.org/Rev2Tour/resized/IMG_20121202_150706.jpg
And building 'D' ... which is where Revelation Space resized mostly. Underneath the sign on the wall you can see a wooden hatch. This is the airduct to the revspace basement (more on this later).
http://revspace.org/Rev2Tour/resized/IMG_20121202_150726.jpg
A front-view of the right size of building D. The rightmost office is used by Revspace, and the room left of that is the shared common-space of the complex.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150740.jpg
The middle section of Building 'D', showing the entrance.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150755.jpg
The front-door of building 'D', with the familiar iButton reader to the right of it. Revspace participants get an iButton, which when connected to the reader opens the door.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150831.jpg
Inside the hallway is the main staircase, and underneath that is the wiring-closet. At the far-end of the hall are the toilets.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150849.jpg
Going 'right' at the main hallway brings you to the common area
http://revspace.org/Rev2Tour/resized/IMG_20121202_150907.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_150919.jpg
The common area, showing 'The Eye of The Internet' and 'Henk'. There is a kitchen here, and the picknick tabels are mostly used around dinertime.
http://revspace.org/Rev2Tour/resized/IMG_20121202_150939.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_150948.jpg
A quick view into the Revspace office, which at this time is still a bit messy, we just moved in, and haven't gotten around to really using it yet. This office can also be seen from 'cam1'.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151000.jpg
The Revspace pinball table... it's set to free play, so enjoy yourself.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151013.jpg
'Henk', guarding the kitchen
http://revspace.org/Rev2Tour/resized/IMG_20121202_151032.jpg
Further down the hall (passing the pinball table) is another set of doors, behind this is the staircase to the basement.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151051.jpg
The door opposite the stairs leads to the main storage room.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151107.jpg
The door underneath the stairs also has an iButton reader, and leads to the main hackerspace room
http://revspace.org/Rev2Tour/resized/IMG_20121202_151129.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_151145.jpg
A quick view into the storage-room, which also houses some of the heating equipment for the building
http://revspace.org/Rev2Tour/resized/IMG_20121202_151203.jpg
Going to the main hackerspace area...
http://revspace.org/Rev2Tour/resized/IMG_20121202_151215.jpg
We can see the big fridges that keep our caffeine cold, and some movable workbenches with measuring-equipment. Also visible is the hole in the wall, which leads to the hatch we mentioned earlier.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151222.jpg
Our lasercutter and PCB lighting/development equipment.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151231.jpg
The IBM-3151 RevBar terminal
http://revspace.org/Rev2Tour/resized/IMG_20121202_151243.jpg
The Naomi game console and project-shelves.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151250.jpg
The right half of the workshop room, showing project-shelves and enough workbenches
http://revspace.org/Rev2Tour/resized/IMG_20121202_151303.jpg
Our (still to be populated) tool-rack.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151310.jpg
The left half of the workshop room, more storage space and workbenches
http://revspace.org/Rev2Tour/resized/IMG_20121202_151324.jpg
The far-end of the workshop, showing more desks and some of the power infrastructure.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151412.jpg
Back up the stairs, these doors lead to the outside area.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151423.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_151430.jpg
Down the path outside leads to the back-area of the hackerspace. This is also the location of our BigGreenEgg BBQ, which is used the year around.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151452.jpg
A view of the back of building 'D'
http://revspace.org/Rev2Tour/resized/IMG_20121202_151501.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_151529.jpg
Heading towards the 'SparkShed'
http://revspace.org/Rev2Tour/resized/IMG_20121202_151544.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_151558.jpg
The 'SparkShed' is the location where we do our welding, metalwork and plasma-cutting. It's well ventilated and outside of the main building. There is ample power for heavy equipment.
http://revspace.org/Rev2Tour/resized/IMG_20121202_151630.jpg
But subtle projects can also be done in this heavy-metal room...
http://revspace.org/Rev2Tour/resized/IMG_20121202_151824.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_151835.jpg
Back inside, behind the main door, are the toilets... somewhat more for men then for women... but that seems to work out better. Up the stairs is another set of toilets... when needed ;)
http://revspace.org/Rev2Tour/resized/IMG_20121202_151849.jpg http://revspace.org/Rev2Tour/resized/IMG_20121202_152009.jpg
Last but not least, we also have access to a bathroom with 2 showers and 2 sinks. This room can also be used for some light chemical work.
