LGT-92
Revision as of 11:56, 11 November 2020 by Bertrik Sikken (talk | contribs)
Project LGT-92
Improving LGT-12 LoRaWAN tracker software
Status Initializing
Last Update 2020-11-11
What
This page is about the Dragino LGT-92, a GPS-enabled LoRaWAN tracker node.
The plan is to investigate if the firmware can be improved, e.g.:
  • fix minor existing bugs
    • see the Issues page at github
  • add Cayenne encoding
  • collect information on how to interface with it (over the "USB" port)
  • perhaps write a replacement firmware, that can be easily compiled with platformio
As far as I understand:
  • STM32L151 microcontroller, could also be STM32L072 I can't get this really clear
  • GPS
  • accelerometer
  • button, 3 LEDs (R, G, B)
  • 1000 mAh battery + charging circuit
Information provided by Dragino: https://github.com/dragino/Lora/tree/master/LGT-92
My fork of the Dragino firmware: https://github.com/bertrik/LGT-92_-LoRa_GPS_Tracker
Work in progress for an Arduino firmware: https://github.com/bertrik/lgt92
Flashing
When you hold the reset pin (e.g. push a dupont-pin in the hole next to the USB connector), you can communicate over SWCLK/SWDIO debug pins.
ST-Link pin connections (from: https://github.com/dragino/LGT-92_-LoRa_GPS_Tracker/issues/10):
 ST-LINK v2 5.0v  <--> Dupont red pin
 ST-LINK v2 GND   <--> Dupont black pin
 ST-LINK v2 SWCLK <--> Dupont green pin
 ST-LINK v2 SWDIO <--> Dupont white pin
For example:
 openocd -f /usr/share/openocd/scripts/interface/stlink.cfg -f /usr/share/openocd/scripts/target/stm32l0.cfg
TTN mapper configuration
Run these commands to set it up with ABP keys, ADR off, uplink at SF7 every 15 seconds:
 AT+ADR=0
 AT+NJM=0
 AT+CFM=0
 AT+DR=5
 AT+LON=1
 AT+MD=0
 AT+DADDR=26 01 1A 30
 AT+NWKSKEY=FB 09 6B 85 86 AF 47 12 E8 AE 67 CB 7F A9 CB 51
 AT+APPSKEY=CB 9B 8F F5 E6 2C 8E 87 9E 0B 6B 1F 4B 69 14 FA
 AT+TDC=15000
 AT+NMEA886=2
 AT+PORT=1
 AT+FTIME=0
