RGB64x32MatrixPanel
Revision as of 21:18, 12 October 2020 by Costyn van Dongen (talk | contribs) (Added pics)
RGB64x32MatrixPanel on ESP32
For a friend I'm making a RGB LED panel, and need to pull some social media numbers and display them on the panel.
For this I wanted an ESP32 so it could do HTTP REST calls over wifi. I came across this library for efficiently talking to HUB75 RGB panels on an ESP32:
https://github.com/mrfaptastic/ESP32-RGB64x32MatrixPanel-I2S-DMA
Parts List
MCU Pin Issues
The MCU has several pins with limited functionality or they are not connected. The wiring guide suggests using pins 16/17 for example, but on WROVER they aren't connected.
The final mapping I used is:
IO2  G2
IO4  LAT
IO5  C
IO18 CLK
IO19 B
IO21 B2
IO22 OE
IO23 A
IO25 R1
IO26 G1
IO27 B1
IO32 R2
IO33 D
Platformio.ini
The LilyGo TT T7 isn't in Platformio yet, but using a T1 works too:
Pics
