Treinonderdelen
| Project Treinonderdelen | |
| Status | Initializing |
| Contact | Sebastius |
| Last Update | 2019-12-08 |
Catalogus
Coordinatie
Inschrijflijst
Treindisplay intern
- Beschikbaarheid
- Totale aantal: 1908 Afname mogelijk: 492 Frequentie: Per tranche
- Min. afname: 100 stuks Locatie: n.t.b.
- Specificaties
- Materiaal: Aluminium, PC, RVS
- Lengte: 707 mm Breedte: 121 mm Diepte:60 mm
| Nickname | Hackerspace | How to contact | Number of units |
| Sebastius | Revspace | IRC #revspace Sebastius | 3 |
| Jolo | Bitlair | TBA (via polyfloyd) | 1 |
| h3x4d3c1m4l | Revspace | Telegram @h3x4d3c1m4l | 2 |
| minicom | Revspace | IRC minicom | 1 |
| Niels | via minicom | IRC minicom | 1 |
| PBX | Revspace | PBX | 1 |
| bef0re | Hackalot/RevSpace | IRC | 3 |
| Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 1 |
| Archels | Hack42 | Archels in #hack42 | 1 |
| Boots | nurdspace | IRC #nurds Boots | 1 |
| pietdv | Revspace | piet_at_devae.re | 2 |
| rad0 | TechInc | ? | 1 |
| Wizzup | TechInc | ? | 1 |
| eightdot | Bitlair | IRC | 2 |
| Wheeze_NL | RevSpace | IRC | 2 |
| Xesxen | Hackalot | IRC | 1 |
| Flimpie | via Polyfloyd | Telegram @flippylosaurus | 4 |
| Bix | Hack42 | IRC | 4 |
| CrazyA | Frack | IRC | 3 |
| Dreamer | NurdSpace | IRC | 1 |
| Stoneshop | Hack42 | IRC | 1 |
| qguv | Revspace | IRC qguv@freenode | 1 |
| Gopper | Bitlair | Telegram @robmans | 2 |
| XNDR | RevSpace | Phone | 8 |
| FooBar | Revspace | IRC | 2 |
| Sake Blok | badge.team | telegram @kolbekas | 1 |
| Kevin | via minicom | Telegram @GKHill | 1 |
| rad0 | techinc | 1 | |
| kmhn | AwesomeSpace | Telegram @knassar | 2 |
| Mikazuki | Frack | IRC #Frack | 2 |
| You? | ? | ? | ? |
| Current Total | 57 |
Noodremhandel
- Beschikbaarheid
- Totale aantal: 1329 Afname mogelijk: 740 Frequentie: Per tranche
- Min. afname:50 stuks Locatie: nntb
| Sebastius | Revspace | ? | 2 |
| Benadski | Revspace | ? | 4 |
| Boekenwuurm | Revspace | ? | 2 |
| Juerd | Revspace | ? | 1 |
| PBX | Revspace | ? | 2 |
| Lucanator | Revspace | ? | 1 |
| Quint (not qguv) | via minicom | IRC minicom | 1 |
| H3x<tab> | Revspace | ? | 2 |
| thomas | Revspace | ? | 2 |
| cmpxchg | Revspace | ? | 1 |
| Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 2 |
| Muse | TechInc | userpage op techinc wiki | 4 |
| polyfloyd | Bitlair | IRC | 2 |
| eightdot | Bitlair | IRC | 1 |
| forseti | Bitlair | IRC #bitlair | 3 |
| effractuur | ? | IRC | 10 |
| bertrik | Revspace | IRC #revspace | 1 |
| Xesxen | Hackalot | IRC | 2 |
| jelly | Revspace | IRC #revspace | 1 |
| Stoneshop | Hack42 | IRC | 2 |
| Dreamer | Nurdspace | IRC | 3 |
| Kartoffel | Revspace | IRC #revspace | 1 |
| Anus | Revspace | IRC #revspace | 1 |
| Katje | TechInc | IRC | 1 |
| Renze | Tkkrlab | Telegram @r3nz3 | 2 |
| Ultratux | Techinc | IRC | 1 |
| Molenaar | Revspace | e-mail/wiki | 2 |
| Linor | Bitlair | IRC #bitlair | 1 |
| Pwuts | Revspace | IRC | 4 |
| Braldt | via minicom | Telegram @Braldt | 1 |
| Hans | via minicom | ? | 1 |
| Casper | via minicom | Telegram @MrSnowman | 1 |
| Flimpie | via PolyFloyd | Telegram @flippylosaurus | 1 |
| Meathur | via f0x | Telegram @Meathur | 1 |
| chip | techinc | 2 | |
| DWizzy | respace? | Mail, Tg, xmpp | 2 |
| bef0re | Hackalot/RevSpace | IRC | 8 |
| Mikazuki | Frack | IRC #Frack | 1 |
| fhp | hackalot | IRC #hackalot | 1 |
| Okkie | Revspace | postduif? | 2 |
| Redlizard | Hackalot | IRC | 1 |
| You? | Hackerspace? | contact? | nn? |
| Current Total | 89 |
Deurbedieningspaneel
minimale afname 50 stuk, bod 10,- p/s
| webmind | techinc | irc | 2 |
| Wizzup | techinc | irc | 3 |
| effractuur | ? | IRC | 2 |
| minicom + Niels | RevSpace | irc | 2 |
| Wheeze_NL | RevSpace | irc | 2 |
| Xesxen | Hackalot | irc | 2 |
| Ultratux | Techinc | IRC | 2 |
| Boekenwuurm | Hackalot | irc | 1 |
| Linor | Bitlair | IRC #bitlair | 2 |
| Pwuts | Revspace | IRC | 1 |
| holysn0w | via minicom | Telegram @holysn0w | 1 |
| Kevin | via minicom | Telegram @GKHill | 2 |
| Flimpie | via PolyFloyd | Telegram @flippylosaurus | 2 |
| thomas | RevSpace | irc | 1 |
| Meathur | via f0x | Telegram @Meathur | 3 |
| chip | techinc | 1 | |
| DWizzy | respace? | Mail, Tg, xmpp | 3 |
| bef0re | Hackalot/RevSpace | IRC | 1 |
| Redlizard | hackalot | IRC | 1 |
| Current Total | 48 |
Treindisplay extern (It's bigger!)
Minimumafname 60 stuks, a 25 euro per stuk (dat is het minimale bod per unit met een beetje marge).
- Beschikbaarheid
- Totale aantal: 348 Afname mogelijk: 200 Frequentie: Per tranche
- Min. afname: 60 stuks Locatie: n.t.b.
- Specificaties
- Lengte: 1002 mm Breedte: 206 mm Diepte: 66,5 mm
- Display: 160,7 x 948 mm
| minicom (Niels) | RevSpace | IRC | 1 |
| Dreamer | Nurdspace | IRC | 1 |
| h3x4d3c1m4l | RevSpace | Telegram @h3x4d3c1m4l | 2 |
| Eightdot | Bitlair | IRC | 2 |
| bef0re | Hackalot/RevSpace | IRC | 4 |
| You? | ? | ? | ? |
| Current Total | 15 |
Deur extern
Info moet nog worden gecopypaste
| bef0re | Hackalot/RevSpace | IRC | 2 |
| You? | ? | ? | ? |
| Current Total | 2 |
Koplamp
| You? | ? | ? | ? |
| Current Total | 4 |
Speaker versie 1
| bef0re | Hackalot/RevSpace | IRC | 10 |
| You? | ? | ? | ? |
| Current Total | 10 |
