Treinonderdelen
Project Treinonderdelen
Status Initializing
Contact Sebastius
Last Update 2019-11-29
Catalogus
Coordinatie
Inschrijflijst
Treindisplay intern
  • Beschikbaarheid
    • Totale aantal: 1908 Afname mogelijk: 492 Frequentie: Per tranche
    • Min. afname: 100 stuks Locatie: n.t.b.
  • Specificaties
    • Materiaal: Aluminium, PC, RVS
    • Lengte: 707 mm Breedte: 121 mm Diepte:60 mm
Nickname Hackerspace How to contact Number of units
Sebastius Revspace IRC #revspace Sebastius 3
Jolo Bitlair TBA (via polyfloyd) 1
h3x4d3c1m4l Revspace Telegram @h3x4d3c1m4l 2
minicom Revspace IRC minicom 1
Niels via minicom IRC minicom 1
PBX Revspace PBX 1
bef0re Hackalot/RevSpace IRC 3
Martian TkkrLab / Hackalot IRC #tkkrlab martian 1
Archels Hack42 Archels in #hack42 1
Boots nurdspace IRC #nurds Boots 1
pietdv Revspace piet_at_devae.re 2
rad0 TechInc ? 1
Wizzup TechInc ? 1
eightdot Bitlair IRC 2
Wheeze_NL RevSpace IRC 2
Xesxen Hackalot IRC 1
Flimpie via Polyfloyd Telegram @flippylosaurus 4
Bix Hack42 IRC 4
CrazyA Frack IRC 3
Dreamer NurdSpace IRC 1
Stoneshop Hack42 IRC 1
qguv Revspace IRC qguv@freenode 1
Gopper Bitlair Telegram @robmans 2
XNDR RevSpace Phone 8
FooBar Revspace IRC 2
Sake Blok badge.team telegram @kolbekas 1
Kevin via minicom Telegram @GKHill 1
rad0 techinc email 1
kmhn AwesomeSpace Telegram @knassar 2
Mikazuki Frack IRC #Frack 2
You? ? ? ?
Current Total 57
Noodremhandel
  • Beschikbaarheid
    • Totale aantal: 1329 Afname mogelijk: 740 Frequentie: Per tranche
    • Min. afname:50 stuks Locatie: nntb
Sebastius Revspace ? 2
Benadski Revspace ? 4
Boekenwuurm Revspace ? 2
Juerd Revspace ? 1
PBX Revspace ? 2
Lucanator Revspace ? 1
Quint (not qguv) via minicom IRC minicom 1
H3x<tab> Revspace ? 2
thomas Revspace ? 2
cmpxchg Revspace ? 1
Martian TkkrLab / Hackalot IRC #tkkrlab martian 2
Muse TechInc userpage op techinc wiki 4
polyfloyd Bitlair IRC 2
eightdot Bitlair IRC 1
forseti Bitlair IRC #bitlair 3
effractuur ? IRC 10
bertrik Revspace IRC #revspace 1
Xesxen Hackalot IRC 2
jelly Revspace IRC #revspace 1
Stoneshop Hack42 IRC 2
Dreamer Nurdspace IRC 3
Kartoffel Revspace IRC #revspace 1
Anus Revspace IRC #revspace 1
Katje TechInc IRC 1
Renze Tkkrlab Telegram @r3nz3 2
Ultratux Techinc IRC 1
Molenaar Revspace e-mail/wiki 2
Linor Bitlair IRC #bitlair 1
Pwuts Revspace IRC 4
Braldt via minicom Telegram @Braldt 1
Hans via minicom ? 1
Casper via minicom Telegram @MrSnowman 1
Flimpie via PolyFloyd Telegram @flippylosaurus 1
Meathur via f0x Telegram @Meathur 1
chip techinc mail 2
DWizzy respace? Mail, Tg, xmpp 2
bef0re Hackalot/RevSpace IRC 8
Mikazuki Frack IRC #Frack 1
You? Hackerspace? contact? nn?
Current Total 87
Deurbedieningspaneel
minimale afname 50 stuk, bod 10,- p/s
webmind techinc irc 2
Wizzup techinc irc 3
effractuur ? IRC 2
minicom + Niels RevSpace irc 2
Wheeze_NL RevSpace irc 2
Xesxen Hackalot irc 2
Katje TechInc IRC 1
Ultratux Techinc IRC 2
Boekenwuurm Hackalot irc 1
Linor Bitlair IRC #bitlair 2
Pwuts Revspace IRC 1
holysn0w via minicom Telegram @holysn0w 1
Kevin via minicom Telegram @GKHill 2
Flimpie via PolyFloyd Telegram @flippylosaurus 2
thomas RevSpace irc 1
Meathur via f0x Telegram @Meathur 3
chip techinc mail 1
DWizzy respace? Mail, Tg, xmpp 3
bef0re Hackalot/RevSpace IRC 1
Current Total 46
Treindisplay extern (It's bigger!)
Minimumafname 60 stuks, a 25 euro per stuk (dat is het minimale bod per unit met een beetje marge).
  • Beschikbaarheid
    • Totale aantal: 348 Afname mogelijk: 200 Frequentie: Per tranche
    • Min. afname: 60 stuks Locatie: n.t.b.
  • Specificaties
    • Lengte: 1002 mm Breedte: 206 mm Diepte: 66,5 mm
    • Display: 160,7 x 948 mm
minicom (Niels) RevSpace IRC 1
Dreamer Nurdspace IRC 1
h3x4d3c1m4l RevSpace Telegram @h3x4d3c1m4l 2
Eightdot Bitlair IRC 2
bef0re Hackalot/RevSpace IRC 4
You? ? ? ?
Current Total 15
Deur extern
Info moet nog worden gecopypaste
bef0re Hackalot/RevSpace IRC 2
You? ? ? ?
Current Total 2
Koplamp
Current Total 4
Speaker versie 1
bef0re Hackalot/RevSpace IRC 10
Current Total 10
