ZX81plus38 simple to build ZX-81 clone
| Project ZX81plus38 | |
| Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available pin-through-hole parts. | |
| Status | Initializing |
| Contact | mahjongg |
| Last Update | 2019-10-29 |
October 1, 2019 continued
October 30, 2016 First component placement =
I managed to place all the components on the available IC's and gates inside an IC to minimize as much as possible the routing needed, as there is almost no space left for routing.
