ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available parts.
Status Initializing
Contact mahjongg
Last Update 2019-10-13
October 1, 2019 continued
Schematic finished for rev 1.0, updated schematic Bestand:ZX81plus38.pdf, plus preview schematic pictures. Next up, importing the components in the PCB layout, and placement of the parts. No attempts have been made yet to try to support multiple types of ROM/EPROM/FLASH, like the original ZX81 ROM. But this schematic should be complete. New is my attempt to support the canonical cassette loading video bars.
Schematic is now revision 1.1 Bestand:ZX81plus38 rev 1.1.pdf
p.s. on further thought I think I made a mistake in the design of the loading bar logic, the cassette input signal actually produces low going pulses during a load, so is normally high. The logic now is that a low pulse will make the video go low (black) as if its in the front porch, which isn't useful as the video signal is already black, previously during loading the screen went black! So I have to redesign it so the a low cassette pulse actually produces a high going (white) video signal. I will design such a circuit next week, actually I think I will use a circuit that inverts (with an XOR) the video signal during a cassette pulse so it will also work with inverted video..
