ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available parts.
Status Initializing
Contact mahjongg
Last Update 2019-10-06
here is a preview of the schematic so far. Bestand:ZX81plus38.pdf
October 1, 2019 continued
