Eink-word-clock-watch
Revision as of 21:35, 13 April 2019 by Jelly (talk | contribs) (→‎Hardware)
Project E-ink wordclock watch
Contact jelly
Last Update 2019-04-13
Plan
The plan is to make an e-ink watch with a 1.54" display which will display a word clock of the current time which updates every ~ 3/5 minutes.
Requirements
  • Refresh e-ink screen (ie. update word clock) every ~ 3 minutes
  • Be able to set the time or sync it via WiFi/Radio?
  • Capable of running for > one month
Interfaces
  • SPI
  • Serial for debugging / flashing?
  • RTC
Parts
  • e-eink screen datasheet Requiring 3.3 V, SPI and has refresh power req. of 26.4 mW with standby power of < 0.0 17 mW (0.0264/3.3 = 8mA)
  • Coin cell (3V ~ 225 mAh / lithium battery small enough? (if powerful enough) 3.7 V 180 mAh 502025 Lithium Polymeer Li-Po should fit under the display, but might be too big.
  • Display size (e-ink) 31.8mm × 37.32mm × 1.05mm
  • PCB
  • 3d printed case
  • arm strap?
Prototyping
Use a e-ink breakout board with the preferred $MCU to display a simple "hello world" text every three minutes and measure the power usage.
