EspNowSkip
Project EspNowSkip
Music skip button based on ESP-Now protocol
Contact bertrik, jelly
Last Update 2019-03-28
Usage:
  • short press (like 0.5 second) to skip to the next song in the playlist; if no song was playing a new playlist is automatically created and started
  • long press (like 5 seconds) to pair the skip button to the skip receiver; this is normally a one-time procedure
The principle of operation is that the skip button (ESP8266) sends an ESP-Now packet to the skip receiver (ESP32 SHA badge), the skip receiver forwards it to the revspace MQTT, yet another script then performs the actual skip on the audio system.
  • you want it to react reasonably quickly, with little latency between pressing the button and skipping to the next song
  • the skip button should be mobile, so it is battery powered and has to be conservative with current
  • we used to have a wireless infrastructure based on NRF24L01+ modules, this was never really reliable and it got more complicated with incompatible fakes appearing on the market
  • we have a WiFi-based skip button, but it's online continuously, drawing way too much power to make it mobile (so it's tethered to a 5V charger)
The current ESP-Now skip button prototype needs only about 200 ms after powering up to send a message.
schematic
The way it's wired up, is to make the actual physical button just power up the board. A (super-)cap parallel over the supply wires makes it possible to run the skip program to completion from just a single short press. In case a ESP-Now re-initialisation (which takes a bit more time) is needed, you just keep the button pressed for a bit longer to complete the initialization process. This way, the SKIP program starts executing as soon as you press the button and there is zero quiescent current drain on the battery.
Capacitor calculation
 C = I . dT / dV
Battery life
Source code
It contains the following programs:
  • skipbutton.ino: an Arduino program running on the button part (slave, on an ESP8266) which sends the skip message
  • skipreceiver.ino: an Arduino program running on the receiver part (master, on an ESP32) which receives the skip message
EspNowSkip protocol
It works like this:
  • there are two roles:
    • a single central "master" node
    • one or more "slave" skip-buttons
  • when the skip button is pressed, the ESP8266 starts up, reads the last known ESP-Now channel and MAC address from EEPROM and sends an ESP now packet
    • if the skip button doesn't receive an ACK from the central node, it starts a discovery procedure to re-establish the channel and MAC address of the central node
  • the central node is configured as an AP with a specific name (e.g. "espnow-revspace")
  • the discovery procedure tries to find the central node by doing an AP scan, the AP name is the only thing that needs to be agreed upon in advance between master and slave code
    • in the list of the APs, the slave node finds the SSID belonging to the central node, then it also knows the wifi channel and MAC address of the central node
    • the slave node stores both wifi channel and MAC address in (emulated) EEPROM and goes back to sleep
The data we send over ESP-now is an MQTT-like topic and message, separated by a space, for example
 revspace/button/skip jump_fwd
Skip protocol
Classic HTTP GET
where
 p0 is "playlist"
 p1 is "jump"
 p2 is "%2B1", or "+1" escaped
 player is "d8%3Ad3%3A85%3A17%3A30%3A9c", or "d8:d3:85:17:30:9c" escaped, which is the unique id of the particular player instance
Example:
JSON Protocol
To skip to the next song in the play list, on the jukebox audio player software, send a HTTP POST to:
 http://jukebox.space.revspace.nl:9000/jsonrpc.js
with content
Expect a result like:
More buttons modification
adding volume buttons
In its current form, the skip button can only skip.
To get more functionality (e.g. volume up/down) the following could be done:
  • add two more buttons, volume up and volume down
  • when a volume button is pressed, it connects the positive battery terminal to a ESP8266 input pin
  • also it powers up the ESP8266 by connecting the positive battery terminal to the ESP8266 Vcc (through a low-drop schottky diode, e.g. BAT43)
  • the software is modified to check the input pin upon startup, if the pin is active, it performs the action for volume up/down, instead of the action for skip
  • problem (?): the ESP8266 does not have a built-in pull-down, so the pin level is undefined when the button is not pressed -> perhaps add an external pull-down?
    • alternatively, the pins do have a built-in pull-up, so we could perhaps wire it up so we switch the ground pin instead of the Vcc pin
References
Future
  • put it in a nicer case (ceiling cavia watches you skip)
  • add more buttons besides just skipping!
More distant future:
  • use ESP-Now also for other kinds of hacker space infrastructure where low-power consumption is important and/or a power wire is inconvenient: spark shack temperature for example.
  • send data back to the skip button, for example we could send a "now playing" message or album art back to a SHA2017 badge and have it shown on its e-ink display. Complication: there is no easy-to-use Arduino implementation of the e-ink display.
  • add a supercap to the skip button, to allow a short press (e.g. 100 ms) to also be registered -> I have various types in my Samla (e.g. 0.1F 5.5V)..Not needed.
