YetAnotherLedTextProject
Versie door Stitch (overleg | bijdragen) op 25 apr 2012 om 14:33
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
Project [[Project Name::Yet Another Led Text Project [YALTP]|Yet Another Led Text Project [YALTP]]]
Status Initializing
Contact Stitch
Last Update 2012-04-25
Objectives
  • Make a "led-wall" for text to promote the space
  • Learn2led+con-troll
  • It's window sized per character: 40 * 100 cm each.
  • The Blinky project of randomdata sortof matches this one.
Requirements
  • Must be applied on the inside of windows
  • Must not decrease line-of-sight
  • Must have at least one single color
  • Must esthetic appearance "looks like design"
  • Visible parts should have a minimum visibility
  • System should be extensible, from 1 up to 255 characters maximum
  • One component Should cost no more than 10 euros
  • The end result should be removable within 10 minutes per component
  • The end result should be applicable within 1 hour per component.
  • Each component is in fact a 14-component oversized led
  • The system should not eat too much energy
  • The system should work on low power
  • The system is safe and doesn't count harm, fire hazard, heat etc
  • The design would comply to certain standards used by vendors
