A4PaperDispenser
Revision as of 08:22, 9 October 2018 by Bertrik Sikken (talk | contribs)
Project A4PaperDispenser
Dispenses a sheet of A4 paper
Contact bertrik, Sebastius
Last Update 2018-10-09
What is it
This thing is basically a button that dispenses one sheet of A4 paper when pressed. You can press it multiple times to get more sheets. The button is mounted near the laser printer.
The hardware consists of a former elevator button (1st floor) and an ESP8266 (Wemos D1 mini) with the button (active low) on pin D1. The software can be found on its github page.
To compile and upload it, install platformio and run the following command
or install the ESP8266 toolchain in the Arduino IDE and open the .ino file. There is some debug output on the serial port at 115200 bps.
See also https://hacking-printers.net/wiki/index.php/Port_9100_printing
Future ideas
  • Revspace water mark?
  • Date/time header?
See also http://www.frankworsley.com/blog/2011/1/23/printing-directly-to-a-network-printer
graph paper
How about a button that dispenses graph paper (ruitjespapier in dutch)?
The printer should be able to understand postscript, basically a programming language for printers to render graphics.
Here is some code for producing graph paper, written in postscript.
