DustSensor
| Project Dust Sensor | |
| Last Update | 2018-06-06 |
To get an idea of the levels of fine dust around my house, I ordered some dust sensor modules to play around with. In particular, I ordered these ones:
- The Plantower PMS 7003 (AliExpress link);
- The SDS011 (AliExpress link).
The PMS7003 is being advertised as an advanced generation of dust sensor (7th generation), while still reasonably priced (E15,-). They use a laser to perform the measurement and contain a small fan to move the air around.
In parallel with the fine dust level measurement, my device also measures basic meteo data using a BME280 module: temperature, relative humidity and air pressure.
Future work
- investigate whether it is possible to power the dust sensor off a solar panel (backup battery during the night), this would completely eliminate any wiring to the sensor
- improve the casing such that the temperature reading is not influenced as much by direct solar irradiance
- build a luftdaten.info sensor and put it up at RevSpace
- for RIVM samenmeten: automatically determine geo position from wifi APs and the google/mozilla wifi location APIs
- for RIVM samenmeten: use a scheme where the unique id is derived from the ESP id, this should make it very easy to add more sensors with minimal administrative overhead
- create a LoRa version of the software + TTN forwarder so we can put up a sensor at Meteo Gouda (kinderboerderij).
Results
| NodeMCU | PMS7003/BME280 | Remark |
| D3 | PMS7003-RST | Pulled-up to 3.3V on NodeMCU side, may not be actually needed |
| D4 | PMS7003-SET | Pulled-up to 3.3V on NodeMCU side, may not be actually needed |
| D5 | BME280-SCL | I2C-SCL |
| D6 | BME280-SDA | I2C-SDA, |
| D7 | PMS7003-TX | NodeMCU receive, PMS7003 transmit |
| D8 | PMS7003-RX | NodeMCU transmit, PMS7003 receive |
| GND | PMS7003-GND / BME280-GND | GND ground reference |
| VU | PMS7003-VCC | USB voltage (5V) |
| 3.3V | BME280-VCC |
- esp arduino software for reading the SDS011 and sending it as an MQTT stream;
- arduino software for reading the PMS7003 and sending it as an MQTT stream;
- a Java based bridge application that takes the MQTT data produced by the arduino and forwards it to other backends, like the RIVM influx database, luftdaten.info API.
Dust sensor
Libraries used:
- SoftwareSerial (built-in) for serial communication with the sensor
- WiFiClient (built-in) for WiFi connectivity
- WiFiManager (tzapu) to present a captive portal and allow selection of an AP to connect to the internet
- PubSubClient (Nick O'Leary) to handle publishing of data over MQTT
- BME280I2C (Tyler Glenn) and wire for interacting with a BME280 for basic meteo data (temperature, humidity, pressure)
pio run
PMS7003
SDS011
Infrastructure
The idea is that the dust sensor send its data to an MQTT server. From there on, there is an application written in Java that picks up the data from MQTT and redistributes it to other backends, like samenmeten.rivm.nl and luftdaten.info.
The topic that the sensor publishes on is
bertrik/dust/<sensorid>
where sensorid is the id of the ESP8266, in hexadecimal format, e.g. AB12CD
References
Grafana page of my sensor data.
Overview of dust sensor types and comparisons between them:
- Dutch RIVM official air quality map
- Dutch RIVM citizen science air quality map
Dust measurement blog:
Visualizing dust data
Maps
To create a nicely colored map with interpolated dust concentrations:
- I run a Java program that
- reads the luftdaten.info JSON containing 5 minute averages of dust data for all sensors
- iterates over latitude and longitude covering the netherlands
- the (lon, lat) coordinates and weighted average is written to a CSV file
- for each point, it calculates a weighted average of PM10 of all SDS011 sensors, where the weight w is calculated from the distance d as follows:
w = 1.0 / (d * d)
- in QGIS I create the image as follows
- Add a map layer (openlayers, stamen)
- Add a CSV layer from the CSV created by the Java program
- graduated by PM10 value
- spectral color scheme, inverted (blue -> red)
- auto-classify in 15 classes by percentile
- symbol is a square with no borders, size is 8500 map units
- transparency set to 25%
Grafana
Sensor
Telegraf
Things I did:
- influxdb output plugin
- mqtt_consumer plugin
- data_format="json"
- data_type="integer"
systemctl restart telegraf
Grafana
- SELECT field(amb_pm10)
- GROUP BY
- ALIAS BY PM10
Regelgeving
Regelgeving voor fijn stof (PM10) De regelgeving voor fijn stof (PM10) kent twee doelstellingen: - Een grenswaarde voor het jaargemiddelde: 40 µg/m3 als jaargemiddelde mag niet worden overschreden. Aan deze grenswaarde moet sinds 2005 worden voldaan. Behoudens ‘derogatie’ zijn geen uitzonderingen mogelijk (->Derogatie). Deze grenswaarde beoogt vooral bescherming te bieden tegen de langetermijneffecten van fijn stof. - Een grenswaarde voor het daggemiddelde: 50 µg/m3 als daggemiddelde mag op niet meer dan 35 dagen per jaar worden overschreden. 5 Aan deze grenswaarde moet sinds 2005 worden voldaan. Behoudens ‘derogatie’ zijn geen uitzonderingen mogelijk (->Derogatie). Deze grenswaarde is vooral bedoeld om bescherming te bieden tegen de kortetermijneffecten van fijn stof.
Luftdaten.info
I'm forwarding my data also to the luftdaten.info website so it appears on the lufdaten.info map. I use the same kind of mechanism as used for RIVM: write a Java program to capture the MQTT stream and convert it to their API.
Luftdaten.info have a pretty good description of how to build your own sensor for their network. They're keeping it simple, just wire an sds011 dust sensor with some du-pont cable to a nodemcu and put it in a plastic enclosure anyone can build using some drain water piping.
It appears hack42 is also considering to join the luftdaten.info network.
protocol
Most of the Luftdaten.info upload protocols are described on the luftdaten wiki.
- data is sent as a HTTP POST to https://api.luftdaten.info/v1/push-sensor-data/ (NOTE: the trailing slash!)
- the HTTP POST uses headers "X-Pin" and "X-Sensor" (not case-sensitive it appears)
- header "X-Pin" indicates the type of data
- 1 = SDS011 or PMS7003
- 3 = BMP180
- 5 = PPD42NS
- 7 = DHT22
- 11 = BME280
- header "X-Sensor" indicates the unique sensor id, for example "esp8266-9137604"
- header "Content-Type" with value "application/json" (NOTE: API describes this header, but it's not explicitly sent by the implementations above)
- the body of the POST is JSON with the following fields:
- "software_version": string containing the software version of the sender, for example "python-dusty 0.0.1"
- "sensordatavalues": array of structures containing measurement data, looking like this:
- "value_type" (when X-PIN=1): string describing the measurement item type, can be "P1" (PM10 value) or "P2" (PM2.5 value) with dust value in ug/m3 I suppose
- "value_type" (when X-PIN=7): string describing the measurement item type, can be "temperature", "humidity"
- "value_type" (when X-PIN=11): string describing the measurement item type, can be "temperature", "pressure", "humidity"
- "value": field containing the measurement value (NOTE: in string quotes, not as numeric values!)
Other meta-information like latitude/longitude of the sensor is sent by an e-mail registration process. This is linked to your measurements by means of the unique sensor id.
