DustSensor
Project Dust Sensor
Last Update 2018-02-05
I ordered a dust sensor module to perform measurements of airborne dust. In particular, I ordered this one, the Plantower PMS 7003, AliExpress link. It's being advertised as an advanced generation of dust sensor (7th generation), while still reasonably priced (E15,-). It uses a laser to perform the measurement and it contains a small fan to move the air around.
Graph
The data produced by this sensor is sent as JSON to a MQTT server. From there it is picked up by two protocol converters: 1) the Telegraf plugin to insert it into my own influx db and 2) a custom written Java application to forward it to the RIVM samenmeten website
Future work
  • 20180103: joined it with a BME280 sensor, to measure temperature, humidity and barometric pressure. Sometimes things go wrong and it measures every property as 2 billion ... I don't know how to reliably detect and recover from this. Perhaps this is caused by the Wemos D1 mini not having many GND pins so I had to fake one.
  • make it possible to support more than 1 sensor, e.g. also sensors from friends. Like making a distinction between individual sensors using the topic where the data is published.
Results
Data sheets can be found:
The module takes 5V to run and communicates using 3.3V levels. This is a perfect match with an ESP8266 board like the Wemos D1 mini.
Connections
Wemos D1 mini PMS7003/BME280 Remark
D1 TX Wemos receive, PMS7003 transmit
D2 RX Wemos transmit, PMS7003 receive
D3 RST Pulled-up on Wemos side, not sure if actually needed
D4 SET Pulled-up on Wemos side, not sure if actually needed
GND GND
5V Vcc
D6 BME280-SDA I2C-SDA,
D7 BME280-SCL I2C-SCL
D8 BME280-GND Set to GND on Wemos
3.3V BME280-VCC
The software archive can be found at github. Reading measurements works, sending commands to the module does not. I don't know yet whether this is a hardware or software problem.
Libraries used:
  • SoftwareSerial for serial communication with the sensor
  • WiFiClient for WiFi connectivity
  • WiFiManager to present a captive portal and allow selection of an AP to connect to the internet
  • PubSubClient to handle publishing of data over MQTT
  • BME280I2C and wire for interacting with a BME280 for basic meteo data
This dust sensor outputs its data as a 32-byte serial data stream at 9600 bps.
Protocol outgoing data
The protocol for measurement data from the module is that data is sent in frames. Each frame starts with specific begin marker bytes, then a length byte, then the actual data, and finally a checksum. I think it is a good match to use a simple finite state machine to parse the stream and get synchronized to the frames.
Protocol
Value Meaning Remark
0x42 0x4D Begin marker ASCII for characters 'B' and 'M'
0x00 0x1C Length Length of following data
XX YY PM1.0 concentration (ug/m3) CF=1, standard particles
XX YY PM2.5 concentration (ug/m3) CF=1, standard particles
XX YY PM10 concentration (ug/m3) CF=1, standard particles
XX YY PM1.0 concentration (ug/m3) in atmospheric environment
XX YY PM2.5 concentration (ug/m3) in atmospheric environment
XX YY PM10 concentration (ug/m3) in atmospheric environment
XX YY Number of particles >0.3 um in 0.1 liter air
XX YY Number of particles >0.5 um in 0.1 liter air
XX YY Number of particles >1.0 um in 0.1 liter air
XX YY Number of particles >2.5 um in 0.1 liter air
XX YY Number of particles >5.0 um in 0.1 liter air
XX YY Number of particles >10 um in 0.1 liter air
VV Version number ?
EE Error code ?
C1 C2 Check code basically the sum of all bytes up to the check code
Protocol incoming data
Command Protocol
CC Command 0xE1, 0xE2 or 0xE4
HH LL Data Depends on command
References
List of dust sensors:
Dust measurement blog:
Making graphs of dust data
Sensor
  bertrik/pms7003/json {"cf1":{"pm1_0":2,"pm2_5":3,"pm10":4},"amb":{"pm1_0":2,"pm2_5":3,"pm10":4}}
Telegraf
Things I did:
    • influxdb output plugin
    • mqtt_consumer plugin
      • data_format="json"
      • data_type="integer"
  systemctl restart telegraf
Grafana
  • SELECT field(amb_pm10)
  • GROUP BY
  • ALIAS BY PM10
