Luteijn/Vortex
Project "Vortex":
Project Luteijn/Vortex
Contact Luteijn
Last Update 2018-01-30
I've got a four DFRobot 'Vortex' units. Basic programming via the official apps is possible, but rather limited. Luckily, the internal Arduino clone can be directly programmed too. Unfortunately, not all the specs are available, but there are some examples to work with, although they have a quite a bit of 'magic numbers' in them.
Motor Control
still to be documented but seems to be explained fine on the website
LEDs
  FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS);
IR obstacle detector
Seems to be somewhat flaky. Needs a bit more work to figure out. Also, the IR sensor might be useful to read IR remote controllers or beacons.
#define NUM_LEDS 12
// Data pin that led data will be written out over
#define DATA_PIN 13
CRGB leds[NUM_LEDS];
#define IR_IN  7//IR receiver pin
#define L_IR 8  //left ir transmitter pin
int count;
  int i;
  for(i=0;i<24;i++){
    digitalWrite(L_IR,LOW);
    delayMicroseconds(8);
    digitalWrite(L_IR,HIGH);
  int i;
  for(i=0;i<24;i++){
    digitalWrite(R_IR,LOW);
    digitalWrite(R_IR,HIGH);
    PCICR |= 1 << PCIE2;
  count++;
void obstacleAvoidance(void){
  char i;
  count=0;
   leds[5] = CRGB::Green;
   FastLED.show();
  for(i=0;i<20;i++){  //left transmitter sends 20 pulses
    leftSend38KHZ();
    delayMicroseconds(600);
  if(count>10){//if recieved a lot pulse , it means there's a obstacle
    leds[5] = CRGB::White;
    FastLED.show();
    Serial.println("Left");
    delay(100);
  count=0;
  leds[3] = CRGB::Green;
  FastLED.show();
    rightSend38KHZ();
    leds[3] = CRGB::White;
    FastLED.show();
    Serial.println("Right");
    delay(100);
  delay(600);
void setup(void){
  delay(2000);
  Serial.begin(9600);
  leds[4] = CRGB::Blue;
  FastLED.show();
  delay(2000);
  leds[4] = CRGB::Purple;
  FastLED.show();
  noInterrupts();
  pcint0Init();
  interrupts();             //enable the interrupt
void loop(void){
    obstacleAvoidance();
MP3-player
There is an MP3.player integrated in the robot. It can be controlled by sending more or less magic commands over software Serial via pin 11. Pin 2 might be connected to the player too, but my tests so far never had anything received there (like an end of song reached, or even just an 'ack').
An example found on the DFRobot site:
#define MP3_VOLUME 0x10
#define TX 11
#define RX 2
#include <SoftwareSerial.h>
void setup()
  delay(1000);
  mp3Init();
  mp3setVolume(30);//0~255
void loop()
  mp3player(1);
  delay(2000);
  mp3stop();
  delay(1000);
void mp3Init()
    mySerial.begin (9600);
void mp3setVolume(byte vol)
    mySerial.write(buffer, 8);
    delay(20);
void mp3player(byte data)
    delay(20);
void mp3stop()
Eyes
Besides 35 predefined eye patterns, it is also possible to upload your own eye patterns.
#include <Wire.h>
#define I2C_WRITE   0x00
uint8_t serial=0;
void setup(){
   Wire.begin(); // join i2c bus (address optional for master)
   defined_eyes(6,1);
   delay(2000);
void loop(){
   defined_eyes(1,serial);
   serial++;
   if(serial>=35) serial=0;
   delay(250);
   Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4
   Wire.write(serial);  //preset eyes 0~34
   Wire.endTransmission();    // stop transmitting
void custom_eyes(uint8_t color, uint8_t eyeline[10]){
   uint8_t index;
   // right eye         left eye
   //1  2  3  4  5      25 24 23 22 21
   //6  7  8  9  10     20 19 18 17 16
   //11 12 13 14 15     15 14 13 12 11
   //16 17 18 19 20     10 9  8  7  6
   //21 22 23 24 25     5  4  3  2  1
   Wire.write(0x55);  // color 55=custom eyes follow
   Wire.write(0xAA);  // ?? AA=color followed by 10 bytes, each defining one line
   Wire.write(color&0x7);         //color 1-B,2-G,4-R of foreground
   for (index=0;index<10;index++) {
     Wire.write(eyeline[index]);
void example_eyes() {
   Wire.write(0x1c);
   Wire.write(0x18);
   Wire.write(0x10);
   Wire.write(0x1f);  // top row all 5 bits lit
   Wire.write(0x0f);  // leds 6,7,8,9 on 10 off
   Wire.write(0x07);  // 11,12,13 on,  14,15 off
   Wire.write(0x03);
   Wire.write(0x01);
