DustSensor
Project Dust Sensor | |
Experiments with a dust sensor | |
Status | Completed |
Contact | bertrik |
Last Update | 2018-01-01 |
I ordered a dust sensor module to perform measurements of airborne dust. In particular, I ordered this one, the Plantower PMS 7003, AliExpress link. It's being advertised as an advanced generation of dust sensor (7th generation), while still reasonably priced (E15,-). It uses a laser to perform the measurement and it contains a small fan to move the air around.
Results
Data sheets can be found:
The module takes 5V to run and communicates using 3.3V levels. This is a perfect match with an ESP8266 board like the Wemos D1 mini.
Wemos D1 mini | PMS7003 | Remark |
D1 | TX | Wemos receive, PMS7003 transmit |
D2 | RX | Wemos transmit, PMS7003 receive |
D3 | RST | Pulled-up on Wemos side, not sure if actually needed |
D4 | SET | Pulled-up on Wemos side, not sure if actually needed |
GND | GND | |
5V | Vcc |
The software archive can be found at github. Reading measurements works, sending commands to the module does not. I don't know yet whether this is a hardware or software problem.
Libraries used:
- SoftwareSerial for serial communication with the sensor
- WiFiClient for WiFi connectivity
- WiFiManager to present a captive portal and allow selection of an AP to connect to the internet
- PubSubClient to handle publishing of data over MQTT
This dust sensor outputs its data as a 32-byte serial data stream at 9600 bps.
Protocol outgoing data
The protocol for measurement data from the module is that data is sent in frames. Each frame starts with specific begin marker bytes, then a length byte, then the actual data, and finally a checksum. I think it is a good match to use a simple finite state machine to parse the stream and get synchronized to the frames.
Value | Meaning | Remark |
0x42 0x4D | Begin marker | ASCII for characters 'B' and 'M' |
0x00 0x1C | Length | Length of following data |
XX YY | PM1.0 concentration (ug/m3) | CF=1, standard particles |
XX YY | PM2.5 concentration (ug/m3) | CF=1, standard particles |
XX YY | PM10 concentration (ug/m3) | CF=1, standard particles |
XX YY | PM1.0 concentration (ug/m3) | in atmospheric environment |
XX YY | PM2.5 concentration (ug/m3) | in atmospheric environment |
XX YY | PM10 concentration (ug/m3) | in atmospheric environment |
XX YY | Number of particles >0.3 um | in 0.1 liter air |
XX YY | Number of particles >0.5 um | in 0.1 liter air |
XX YY | Number of particles >1.0 um | in 0.1 liter air |
XX YY | Number of particles >2.5 um | in 0.1 liter air |
XX YY | Number of particles >5.0 um | in 0.1 liter air |
XX YY | Number of particles >10 um | in 0.1 liter air |
VV | Version number | ? |
EE | Error code | ? |
C1 C2 | Check code | basically the sum of all bytes up to the check code |
Protocol incoming data
CC | Command | 0xE1, 0xE2 or 0xE4 |
HH LL | Data | Depends on command |
References
List of dust sensors:
- Dutch RIVM air quality measurement project
Dust measurement blog:
Making graphs of dust data
Sensor
bertrik/pms7003/json {"cf1":{"pm1_0":2,"pm2_5":3,"pm10":4},"amb":{"pm1_0":2,"pm2_5":3,"pm10":4}}
Telegraf
Things I did:
- influxdb output plugin
- mqtt_consumer plugin
- data_format="json"
- data_type="integer"
systemctl restart telegraf
Grafana
- SELECT field(amb_pm10)
- GROUP BY
- ALIAS BY PM10
