DustSensor
| Project Dust Sensor | |
| Status | Initializing |
| Last Update | 2017-12-03 |
I ordered a dust sensor module to perform measurements of airborne dust. In particular, I ordered this one, the Plantower PMS 7003, AliExpress link. It's being advertised as an advanced generation of dust sensor (7th generation), while still reasonably priced. It uses lasers to perform the measurement and I think it contains a small fan to move the air around.
Data sheets can be found:
The module takes 5V to run and communicates using 3.3V levels.
It attempts to make an estimate of the number of particles per size category. It also gives an estimate of the total mass of the particles.
I plan to connect this thing up using an ESP8266.
The software archive can be found at github.
This module outputs its data as a 32-byte serial data stream at 9600 bps.
Protocol outgoing data
The protocol for measurement data from the module is that data is sent in frames. Each frame starts with specific begin marker bytes, then a length byte, then the actual data, and finally a checksum. I think it is a good match to use a simple finite state machine to parse the stream and get synchronized to the frames.
| Value | Meaning | Remark |
| 0x42 0x4D | Begin marker | ASCII for characters 'B' and 'M' |
| 0x1C | Length | Length of following data |
| XX YY | PM1.0 concentration (ug/m3) | CF=1, standard particles |
| XX YY | PM2.5 concentration (ug/m3) | CF=1, standard particles |
| XX YY | PM10 concentration (ug/m3) | CF=1, standard particles |
| XX YY | PM1.0 concentration (ug/m3) | in atmospheric environment |
| XX YY | PM2.5 concentration (ug/m3) | in atmospheric environment |
| XX YY | PM10 concentration (ug/m3) | in atmospheric environment |
| XX YY | Number of particles >0.3 um | in 0.1 liter air |
| XX YY | Number of particles >0.5 um | in 0.1 liter air |
| XX YY | Number of particles >1.0 um | in 0.1 liter air |
| XX YY | Number of particles >2.5 um | in 0.1 liter air |
| XX YY | Number of particles >5.0 um | in 0.1 liter air |
| XX YY | Number of particles >10 um | in 0.1 liter air |
| VV | Version number | ? |
| EE | Error code | ? |
| C1 C2 | Check code | basically the sum of all bytes up to the check code, "eight" |
Protocol incoming data
References
- a nice list of sensors from "samen meten aan luchtkwaliteit".
- another nice overview of dust sensors.
