Lasercutter1
Revision as of 23:39, 16 January 2012 by FooBar (talk | contribs)
Project Lasercutter
Status Working"Working" is not in the list (Proposed, Initializing, In progress, Completed, Stalled, Abandoned) of allowed values for the "Project Status" property.
Contact Walter, FooBar, GMC
Last Update 2012-01-16
Lasercutter Checklist
  • Fans are turned on
  • The water is cool
Then, when making a print/cut
  • Do a test-run first, with the laser power disabled, to see if your design works without errors or hitting the borders
Where to get nice material for lasercutting
