Flighttracker
Revision as of 19:06, 5 June 2017 by Jelly (talk | contribs)
Project Flighttracker
Revplane tracker
Contact jelly
Last Update 2017-06-05
RevFlight tracker
With a simple RTL-SDR it's possible to receive flight "beacons" which a commercial aircraft emits. There is software which in combination with an DVB-t receiver can show the planes flying in the area.
Setup
  • Connect your DVB-T receiver
  • git clone git@github.com:MalcolmRobb/dump1090.git
  • Run `make` (note that you need to have rtl-sdr installed)
Note: On Arch use the dump1090-git package from the AUR
Yet another fork of dump1090 has range support and can identify the origin of the aircraft.
Running
  • Run ./dump1090 --interactive --net
  • Open http://localhost:8080/ in your browser to see an interactive google map
Monitor
The plan is to create a sonar like display of the current airplanes. dump1090 kan dump the raw msg (? hex encoded). There is a Python library which might make it easier to decode the messages from dump1090
Images
alt text
alt text
